laknox
Feb 03, 2017Nomad
DCamp84 wrote:laknox wrote:DCamp84 wrote:
Ok let's try this again. Being new to forums and trying to work everything from a "smart phone" is getting me in trouble lol. I had a question I thought of on my way to work this morning. How many (if any at all) store your fivers up off the ground on jack stands during your off season. Would you recommend it? Is this even a correct method of storage? If so, would the continuous weight/ pressure on the points of contact hurt the trailer in any way? Ps. I have a dirt driveway. Thank you for your input
Damon,
Long Island, NY
Easiest thing to do is to run your wheels up on some boards, dress the tires with a =good= protectant (i.e. NOT a "shine", but an actual protectant, like Aerospace 303), then cover them completely. If you'll be in and out frequently, drop the rear stabilizers...or not. With ST tires, I don't think it makes a hill of beans difference if you put 6 or 8 jack stands along the frame and took the tires off and stored them inside; they're going to "age out" (almost NO RV tires actually wear out, unless there's another issue going on) after 5 or 6 years and you'll need to replace them.
(cynic mode off)
That being said, I've run a set of cheap ST tires for right at 6 years before they all 4 went bad in about a week, fortunately while I was moving my FW from storage to my house and some short "town trips". I knew I was pushing things and I didn't get burned, but I certainly could have.
Lyle
Thanks Lyle! Just to clarify the "ST" when you say "ST tire". What does that mean.
"ST" is a trailer-only tire; "special trailer". Frankly, the vast majority ain't so special; they're junk. If you have anything with 16" wheels, you can put LT (light truck) tires on them and get much greater longevity and peace of mind with them than with most STs. That being said, there are a couple brands of ST tires, especially in the 15" size, that are much better than the rest. Maxxis is probably top of the heap, though they still have the 65 mph speed rating and they do have occasional failures for, seemingly, no reason. Carlisle, which was one of the worst a decade ago, came out with a completely re-engineered ST tire line that is, IMO, the equal of the Maxxis, despite being made in China (Maxxis is made in Thailand and/or Taiwan, IIRC). I have a set of Carlisles on my FW, going into the 4th year, and they have a bit of weather checking, but otherwise look, and tow, excellently. The Carlisles also have a higher speed rating, into the high-70's/low 80's, so that tells you something, too. Not that I tow that fast, but if I stay at my usual 60-65 mph, I should have plenty of "safety margin".
Lyle
About Fifth Wheel Group
