Grodyman wrote:
Well, lets just say faster than the WFCO converter. I purchased a Schumacher SC1281 and it seems to work ok, am trying to decide if I want to keep it or go in another direction. I don't want to modify the WFCO in case I sell the trailer.
NOPE.
Not gonna happen..
You ARE more than welcome to try though.
According to Schumachers own manual
HERE , a 105Ahr battery will take 8 hrs to charge at 10A rate on a 50% discharged battery..
The "30A and 100A" ratings are INTERMITTENT use and ARE designed for STARTING YOUR VEHICLE, not for CHARGING A BATTERY.
Your WFCO is rated CONTINUOUS for the amperage rating given..
However, consider this, in order for any charger to charge at a greater rate you need several things to happen.
Batteries must be fairly depleted AND the "charger" MUST have a GREATER VOLTAGE to sustain a higher rate.
Being most converters and chargers for 12V batteries WILL top out at 14.4V, maybe the odd one that might push it to 14.7V the odds are you WILL have wasted yet more money.. The charge current goes hand in hand with the VOLTAGE delivered.
You can put 100 100A 12V chargers on one battery and yet maybe at the most see 10A if the chargers voltage is not high enough.
If you really wish to push some boundries, you need to contact the resident mad battery charging scientist Mexicowanderer on the forum..
And by the way, your WFCO CAN charge faster without "modifications" to the converter..
Simply UPGRADE the wiring from the converter to the battery..
Typical RV wiring while it can accommodate the current of the converter it is undersized which results in large voltage losses by the time the voltage gets to the battery..
With 12V, voltage loss is an issue, small ga wire plus long runs = voltage loss..
But, the way you are going about it, isn't going to make your batteries charge faster, but hey, your wallet WILL be much lighter in the process.. But feel free to knock yourself out trying.
