- VulcaneerExplorerChris and bpounds are both right. Adding to that, my experience is they are on 24" centers when aluminum studs....16" C to C if wood studs. And I think most exterior wood studs are 2X3. While interior studs are 2X2. Not sure of the size of alum. studs.
- Dayle1Explorer IIAgreed with both previous posts. Studs will likely be on 16 inch centers when possible. Also, wherever you see a joint between interior panels on the inside you will find a stud and 16 inches from that you should be able to see a few caulked nail heads.
- bpoundsNomadUse a stud finder.
There isn't enough uninterrupted wall on most trailers for much consistency of spacing. I'm sure they have a design minimum, but the knowledge isn't worth much to us. - Me_AgainExplorer IIISometimes early in the morning you can see the stud pattern on the outer skin! Chris
- 1492ModeratorMoved from Forum Technical Support
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
