Eyetattoo's avatar
Eyetattoo
Oil question?
I have a Guardian by Generac generator and was wondering if any type of oil will work or if I need generator specific oil (if there is such a thing)? It calls for either 10w-30 or 5w-30. Thanks.
  • Eyetattoo wrote:
    Ok perfect, I figured regular motor oil would work. I'll go pick up a qt of synthetic and change it all out. Thanks again.
    Yup that works....
  • Ok perfect, I figured regular motor oil would work. I'll go pick up a qt of synthetic and change it all out. Thanks again.
  • I use generic 5w 30 full synthetic in my generic big generator at the s&b. That, after doing some research on the inter webs. If you have your manual available (don't ask), use what it recommends.
  • My Onan suggests oil depending on temp range of use. I use 14W-40 since I use the generator in the winter. You should have a chart in your manual.
