rhagfo
Feb 24, 2015Explorer III
copeland343 wrote:
Static load on axle and tires no problem. Static load axles and tires can support a lot of weight. Dynamic load (moving) problem. Changing your tires like you suggested is not a problem. And enjoy you trips.
I agree as long as it isn't moving. My 1st choice would be just take to the tire shop. second would be to use a jack to lift the tire just off the ground to remove the tire. Best choice would be to just support the frame on cribbing, and I would never connect to the TV to do this.
This is our old King of the road totally supported by 2X4 cribbing and the landing gear. I did this to "Flip the Axles" it was solid as a rock! I will be doing this shortly with the current 5er to install the correct Track system.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
