Dtank
Feb 26, 2015Explorer
Artum Snowbird wrote:
Also, looking into the manual, it does not recommend that you jack on the axles, but instead jack on the frame.
The frame!
Check the axle mfgr's recommendations also.
No big deal to leave it attached to the TV -and/or- use *two* bottle jacks.
One in front - one in the rear of the wheels (under the *frame* on the same side).
You (the OP) obviously asked - as there is some doubt involved in your plan..:h
The ramp and/or shackle proponents aren't going to donate bucks for any repairs you may incur for damage using their methods..:R
You can look at mfgr "recommendations" as CYA (for the mfgr), common sense, or whatever.
The ramp/s or "jack under the shackles" option/s are your dice to roll.
Whatever rings your chimes!..;)
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
