bacmb's avatar
bacmb
Old new Open Range
Just picked up a 2015 3x349rls. New to fivers, and traveled s long ways to get this one. I believe (operative word is 'believe') i got a good deal, but there are a couple of concerns I'd appreciate feedback on. First, there are cracks in the edge seal/ caulk on the roof. The corners are very poorly done, owner swore whatever was done was by dealer. I'm not terribly worried about those, just not sure whether to strip off and start clean, ourcaulk over. Pictures attached.
The second is a much larger concern. I found a bubble about the size of a hand in the corner of the pin area, on the door side. Sent this to open range (heartland?), and got a pretty quick response that the tech was pretty certain this was frame flex, not delamination. He gave me a measuring test to try, and RV had to stay under 1/8" difference to pass. Measure between spot on pin and spot on jack while jacked and while hooked up on tow vehicle, weight off of jacks. It appears to be between 1/16 and 1/8. I'm thinking I should pull down to dick Gore and let them evaluate.
Am I being overly cautious? Thoughts?
Thanks in advance for any input!
Chuck
Link to photos
