gery_L
May 10, 2016Explorer
fj12ryder wrote:
If you prefer we can continue this in PM's. But I have a couple questions if you don't mind.
What does the conversion consist of?
Is it reversible?
Approximately how much usage time do you get from a 30# propane bottle?
The reason I'm asking is that I would like to do this if the propane run time is not much, much less than on gasoline. I use my tank infrequently and it would be nice not to have to worry about forgetting to drain the carb and having it gum up. I have space, unused presently, for a third propane tank that I could dedicate to the generator. Would this be a wise way to go about it?
Any info would be appreciated and I can use the PM if you'd prefer, but the 5500 is a popular OEM suppled generator and I thought it might be of interest to people other than me.
The link that I embedded in my reply below is the entire kit. This is the one that I purchased. It comes with a very good installation set of instructions, and the seller is very good at communication and can answer any set of questions you may have. He did for me when I was initially contemplating his system.
It is all bolt on, and removes the lower bowl of the Carb. But you will need to plumb the propane line to the regulator. I also put a 12volt inline switch/valve that is only open when the generator is running. The propane jetting screws directly in but the instructions state that it may be necessary to drill a 17/64 hole to match the SPUD. I did it a couple years age, and don't recall if I drilled or not. but have never desired to go back to gasoline.
As far as usage time, It is less than with gasoline, and I don't have any exact #'s because I use 2 100# tanks in the garage, and have never run the hours. I care more for the cleaner burning exhaust and the better running at elevation, (as I hunt/camp in 7000 elevation, and that is where I use it the most).
I would say not quite an hour/gallon.
An On-Line search can give you estimations. It looks like others see 10-12 hours for a 40# bottle.
Hope this helps your decision. I have never looked back.
Gery
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
