dalefuji's avatar
dalefuji
Onan 5500 Generator in Holiday Rambler 1998 Endeavor
Generator runs sometimes and then shuts off.
Replaced with new:
Spark plugs, oil change, oil filter, air filter. "still no run"
Replaced:
New carburetor, New fuel pump, New fuel filter, No gas line hose from carburetor to fuel pump.
"still no luck"
The in line 10 amp fuse above stop/start switch is okay. The 20 amp
two blade fuse by breakers is okay.
I help "stop button" in for 15 seconds to prime Gen. and then hit start button and it started and ran for 60-90 seconds and then started getting rough and shut off and would not start.
I ordered new 5 blade relay plug under air intake to see if that is problem.
Are there any other in line fuses that could be problem
Any suggestions would be greatly appreciated.
