Rick_Jay
Jul 31, 2023Explorer II
dalefuji wrote:
Yesterday I spoke to friend at RV Dealership and he told me to hold stop button in for 15 seconds to prime carb. I did that and generator started and ran for about 3-4 minutes. After that it would not start. Today we disconnected gas line from main tank to fuel pump and hooked hose up to fuel pump and dropped hose in gas can. Generator would not start.
When you primed the generator, it started. I'm assuming it was running pretty well and not sputtering or running rough or you would've mentioned that. That to me would suggest that the carb is probably OK.
After you primed it, it ran, and then stalled once the fuel was used up in the float bowl. That's normal if there's not sufficient fuel being fed to the carb. Did you repeat the priming procedure every time you tried to restart it after that? If you just dropped the fuel line into a can of gas, it'll take A LOT of cranking before it can pull up enough fuel into the float bowl to fire.
Well, good luck in your troubleshooting. I'm still leaning toward it being a fuel line or possibly a fuel pump problem. I'll be very interested to hear what your solution turns out to be.
~Rick
