danmarken1's avatar
danmarken1
Holiday Endeavor Wiring
Does anybody know where the communication wiring diagram(s) can be found for 2018 Holiday Rambler Endeavor XE? Purchased a "used" 2018 HR and am trying to determine where the various Cat 5, HDMI and Coaxial Cables run/terminate and service each provides. Unit has King-Tailgate(Dish svc) mounted on roof near front with two Wally receivers.
  • danmarken1 wrote:
    Thanks MountainAir05. Turns out wiring (Cat-5, HDMI and coaxial) cables are terminated/switched behind "false" wall behind sleeper sofa. Punch down for cat-5 cable with interface to HDMI switch boxes and HDMI splitters. The unit is wired to support two tv's for each Dish Wally box(es) (2) and two tv's for each DVD player (2) as well as internal internet & Wifi hotspot setup. Ever look at a can of worms?
    Glad it work out for you .
  • Thanks MountainAir05. Turns out wiring (Cat-5, HDMI and coaxial) cables are terminated/switched behind "false" wall behind sleeper sofa. Punch down for cat-5 cable with interface to HDMI switch boxes and HDMI splitters. The unit is wired to support two tv's for each Dish Wally box(es) (2) and two tv's for each DVD player (2) as well as internal internet & Wifi hotspot setup. Ever look at a can of worms?
  • Should be a start in the electric cord compartment, which runs to the front of the Rv to a inside cabinet. In that cabinet should be your control box for the cable and Tv antenna. From there to the front tv and to the where your other TVs are located. This is just general.
