dougrainer
Jul 31, 2023Nomad
dalefuji wrote:
The spark plug gap is set at .025 and plugs come set at .035 could an issue.
I always kept oil level at full mark, some say that oil level should be at
low level mark because dip stick is wrong?????
Is there a sensor on oil level that could be causing Onan not to start??
The Onan WILL start with the switch engaged. IF you have a LOPKO(low oil pressure switch) that is defective the Onan will then die once the start button is released. There is NOT any such problem with needing to have Oil Level lower than full on the mark. Where did you get your Carb? ONAN carb or aftermarket? Fuel Pump. ONAN or aftermarket or local auto part store. Doug
