allcool wrote:
nayther wrote:
Another thing to look for is degradation of the rubber fuel lines. with the crappy ethanol in the fuel it eats at the rubber. My fuel station line between the tank and pump was toast due to this. I replaced the entire fuel line from tank to pump with 3/8 copper, short rubber hose on each end that is rated for the new fuel.
JFYI,,,
With all due respect, my opinion...
Copper is not the best choice for fuel lines on vehicles, at all.
An unbalanced tire at hyw speeds can set up substantial vibration that kills copper tube fast. If its mounted tight, every 6-8", might still be ok. But then chafing comes into play. And copper is very susceptible to chafing thru with continious vibration with a hard surface.
Copper (especially 3/8" copper tube) work hardens under vibration. Then is prone to cracking and fuel leaks. Coppers very good heat transfer properties make for a easier tendency to vapor lock.
If you don't want to use a quality fuel rated hose, then use copper clad steel fuel lines, or the new Ni-Cop tubing.
jmo
I wondered who would chime in on that. We've been using copper for fuel lines for decades. If I can find it I'll post a picture of a replication race car from 1950's with copper fuel line. Yes it will work harden if its subject to extreme movement, this will not move much, it's zip tied up inside the frame pocket. From your screen name I assume you're an A/C guy, me too, been working around copper for MANY years. This installation will outlive me.
