mbrule wrote:
Hope I am not Hijacking, but this seemed like a good place to ask and help continue the discussion, if not I apologize.
I too am looking for tire opinions. Lost two (yes 2) due to tread separation on a 400 mile run yesterday. Got lucky on the first with minimal trailer damage. The second made up for that!!
Anyway when looking up some of the recommended tires in this thread I found the Goodyear G614 RST:
http://www.goodyeartrucktires.com/tires/details.aspx?prodline=160007
Is this the G614 that you guys are referring to? Good year is touting it as good for trailers.
Edit I should note My fiver has a 15K GVW, I have not weighed it, but suspect I am on the heavy side I carry a lot of crap!
Another edit, the max inflation on my current wheels is 80 PSI. Should I be replacing them as well? If so any recommendations?
I changed out my GY E tires to GY G's with 80psi wheels. Using the weight/inflation chart I ran the tires at 85psi for 5 years with even tread wear.
With anything there is a margin on ratings. I will only run GY G or H tires.
