Guys, Looks like I have my trailer probably has 6000 lb axles.
The spec sheet indicates that it should have 15 inch tires, 5000 lb axles, and GVWR of 11900.
The tag inside a cabinet door indicates that it has a 11037 Dry weight and 14000 lb GVWR.
I am assuming the tag on the coach is correct, I have contacted Newmar for clarification.
The tires are 235/85R16E (3040 lbs single). I bought the rig used, so I am assuming that the tires were likely changed by the first owner.
I am inclined to think that I should go up a load range or at least get a load range E with a higher weight capacity, to have some safety margin??????
