CYCLEPATH
Jun 19, 2023Explorer
Open Ground
Hello all. Just made the jump from my Lance camper, which I loved, to an Alliance Paradigm 310RL. It's a beautiful rig. The day after bringing it home, I was going over the electrical system. It h...
BB_TX wrote:
If you have an open ground, your GFCI outlets are not going to trip on a ground fault.As you explain later a ground fault cannot happen because there is no ground reference They require an electrical path to the power source neutral-ground bond to trip. And if you should have a hot wire shorted to ground or RV frame it will not trip the circuit breaker. It will create a hot frame though. None of which are good conditions. .
