rvoorhis318's avatar
rvoorhis318
Open Range Owners Any Problems
Our dealer is fantastic but the quality of the build is not so! We've had close to 15 warranty trips to the dealer in the first year:
- all four bearing seals failed on one trip
- dining table & chairs all missing half the screws and the screws were so short the one chair seat came off in my wife hands
- Slide switches not providing adequate power to slide motors
- Bad electrical outlet
- Awning LED lights failed
- Black tank cable broke while in Florida
- Shower door latch cheap plastic doesn't work
- All drawers only 2 screws most have fallen out during travel
- Drawer under oven cabinet frame broke because drawer latches aren't strong enough to keep drawers closed during travel
- Furniture tie down rings cheap & flimsy only one screw, put tension to make things tight and they pull out of the floor
- All interior slide trim has fallen off, held on by minimal strips of adhesive and tiny staples
This is a 2014 345RLS Open Range have had it just over a year, my warranty issues were addresses however, its cost us a small fortune in gas back & forth to the dealer and time lost using the coach for our enjoyment. Open Range has some serious quality control issues and why do they get away with it, because we fix all of their mistakes by making suspension upgrades, replace all the cheap **** with quality parts and make sure the repair work is done properly.
If everything was all good I wouldn't be writing this and its all documented with warranty repair receipts, photos and videos. Today they offered me $425.00 a goodwill offering as they put it for my troubles, I told them to keep it I'd rather tell folks my story. Mind you, my warranty issues were addressed and repaired by either dealer, myself or a carpenter friend of mine but the coach is still dropping sawdust all over everything every time we go out. Should we be breathing this stuff, could it be harmful, any chemicals in that wood we should be worried about, I don't know but I'm going to do my homework on the issue. Quality is a big concern do your homework!!
  • I am hooked up taking mine back for some much needed love after a few shake down trips. Did not surprise me we had a few glitches this summer. I expected that. There were a few that kinda make my mad but again, nothing I didn't expect. Here is some of the things getting worked on
    1 Fridge, won't cool on propane. This one has been a real PIA all summer
    2 Awning lights out, went out very first trip
    3 Dining chair has to be replaced, they put a screw in at an angle and popped the wood in the seat (never even used it)
    4 TV is horrible, loose connection somewhere in the cable (antenna works great)
    5 Living room slide rubs on the ceiling, should be a minor adjustment
    6 bedroom and bathroom doors both need adjustment
    7 driver side wheels seals both bad
    There were a few other things I can't remember off the top of my head but all were pretty minor.
    Looks like we had similar problems on a couple of things but ours is holding up much better than yours. Not sure if you had a Friday build or what but I don't think your issues are indicative of Open Range quality.Our last trailer (Keystone Sprinter) was in and out of the dealer like a revolving door for the first 6 months! Every time that shop touched it they messed it up worse. They are now closed up! Get the bugs worked out and then enjoy your rig
  • Yeah sadly EVERY MFGer has some quality issue's some folks get great one's with very little problems and some get the Lemons ,I am sure there are a lot of Open Range Owners that have had very few problems Hopefully you will get the Bugs out and enjoy it from now on
  • tsetsaf wrote:
    Your issues seem standard for the biz... wait a couple years for the grey front cap to start fading then you will want that $400 goodwill gesture.
    And ad that $400. to another $1100. and you can have it painted.
    B.O.
  • Your issues seem standard for the biz... wait a couple years for the grey front cap to start fading then you will want that $400 goodwill gesture.
  • For previous posts search this Forum for `Open Range' then search the results for `problem' or `trouble' etc.
