JIMNLIN
Aug 10, 2014Explorer III
op says+ wrote:
Funny thing, I was just doing some research and realized the same that the axles are practically the same. The one difference I did notice is the number of splines in the diff. The 6200# has 35 and the 7000# has 37 spline. How mush of a concern is this for the weight rating?
This gets talked about all the time when the the Ford 3/4 vs one ton SRW issue is brought up. According to Ford truck folks the 37 spline axle should be under the F350 DRW/F450 Dana 80 axle heading on page #71 in Fords spec website .
The F250 and F350 SRW uses the Visteon 35 spline axle.
Actually the number of spline/axles diameter has more to do with twist GCWR/tow ratings) than carrying a load (GAWR) on a full floating axle. The axle on a full floater doesn't carry the load.
About Fifth Wheel Group
