- pigpen1003ExplorerThis is pigpen again just an update, I stated that my lippert 6 point leveling system had a low voltage reading on the control panel. But the gen and land hookup worked fine. Took out my batterys to take down where I bought them and they tested good. Started reinstalling them and low and behold my ground cable crimp on connection fell off!!! after reconnecting the loose ground cable all is well again. Now I can push a button and sit back and drink a cold one.
- RustyJCExplorer
Arcamper wrote:
I saw this post back in May and did not think much about it. We have the 6 point on our new Montana and yes its great. However I think this is the first post I have seen in 8 years that every single person agrees on something and no one talks it down even though its made by the dreaded Lippert Ind. Go figure.
Maybe it's because Lippert didn't design it - they bought rights to the LevelUp system.
Rusty - ArcamperExplorerI saw this post back in May and did not think much about it. We have the 6 point on our new Montana and yes its great. However I think this is the first post I have seen in 8 years that every single person agrees on something and no one talks it down even though its made by the dreaded Lippert Ind. Go figure.
- ken_burkeExplorer
PMiller228 wrote:
We are about to place on order on a Sandpiper 371REBH and I'm considering the Lippert 6 pt. leveling system. It's a $2,000 option. What is everyone's thoughts on it? Is it a troublesome system or pretty reliable? Does it work well? Thanks!
You might consider the added weight of the hardware. Will the added weight of the 6 pt system put you close to weight limits.
ken - RustyJCExplorerWhat's the battery voltage readout on the LevelUp panel when you arrow through the readouts? Obviously, there's a problem with the supply voltage from the battery to the LevelUp system - could be a loose cable, or your new battery might have a weak or defective cell. I'd take it back where I bought it and have it load tested. The fact that the LevelUp will operate off the power converter when plugged into shore power or running off the generator says that the problem isn't in the LevelUp system.
Rusty - GoPackGoExplorerI would disconnect the battery and check the voltage before doing anything. If new, maybe it was not fully charged before you installed it.
Also check to make sure the cables are not reversed. - pigpen1003ExplorerWhy do I always have troubles with all my trailers? I bought a raptor toybox 2 years ago with 6pt. leveling system. worked great till last week. I have new 12vbatt checked connections, control box on lci says low batt. when I start gen or plug it in with cord it works. I think its the 12v system but cant be sure any thoughts out there would be nice
- benb21601Explorerback in, hit button, open beer. nuff said.
- ramgunnerExplorerThe Level Up system was a $3236 option on ours, and we included it.
- buc1980ExplorerfOR 2000$ OPTION don't even think run and get it.I pay 4700$ to install mine.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
