hbillsmith
May 31, 2015Explorer
Make sure you are indeed being quoted a 6 point level system. Lippert sells the OEM mfg three different systems. A true 6 point hydraulic level, a 6 point electric called ground control 3.0 and a 4 point level also called ground control 3.0. Most dealers sell the electric 4 point auto level paied with a couple of electric rear jacks for $1600-$2000 and call it a 6 point. It is not! A true 6 point is a 1 button press for all 6 jacks. The hybrid auto levels 4 jacks then you step to the back of the RV and manually press the two buttons that lower separately the 2 rear stabilizers. It's very easy to put the 2 rears down without changing the level that the auto-level adjusted to. The hybrid is used on sub-40ft. RV's. I have it and it's just fine.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
