bpounds wrote:
MandM2711 wrote:
Front is 5060
Rear is 3180
I will take a look at the cougar x-lite.
Thanks.
As you can see, you've got plenty of spare capacity on that rear axle. Which is probably rated for 6k or 6.1k. I would use that as my guide. Your tires and wheels will be rated for at least that much.
Your fiver won't put much on the front axle. Not a factor up front.
Not sure the stock tire size, but I went from the OEM 245's on my D'max to 265's and picked up nearly 1,000 lbs more tire capacity. The 245's put me well below the rear axle capacity. I now have more tire than axle capacity.
Lyle
