valhalla360
Jun 19, 2017Navigator
TxGearhead wrote:
Unless you get a Hensley 5th hitch, you may find the hitch is heavy and cumbersome to remove from your truck bed. I discovered using a Harbor Freight 2 ton foldable shop crane works well.
Or just leave it attached to the pin and lift it out with the trailer.
Also 3" is way too little unless you only drive on perfectly smooth roads (which is not realistic). First time you drop one side of the trailer into a deep pothole, your truck bed will meet the 5th wheel overhang. I would suggest 6" as a MINIMUM and more is nice if you can get it.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
