Jhurk
Jun 19, 2017Explorer
I have a 2014 Ram 3500 TD PULLING 14,000 FW. I PUT IN THE Anderson Ultimate Aluminum hitch gooseneck mount. Mounts on a B/W ball in bed of truck that flips under when hitch is removed nice and clean bed. Hitch weighs only 35 lbs which makes it very easy to remove and hang in garage. Hitch rated for 24,000 lbs. works well on short bed box no slider required depending on model of front end of FW and extended pin helps.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
