lamopar's avatar
lamopar
Outdoor speakers leaks, 2nd toy hauler same problem
Thought I might drop a note here of a problem I have had on two toy haulers about 6 years apart. The material that attaches the speaker, woofer part of a two way, separates from the foam type material that attaches the speaker to the speaker frame. Our 2011 had it and I never noticed it and did not have a cover for the unit so when it rained it ran in the speaker, down the wall and destroyed the flooring. Yesterday I was playing some music and noticed a scratchy sound on our 2018 unit. When I inspected the speakers I found the foam had disconnected at the bottom from the speaker. It is very hard to see and you must look for a black line where the foam was attached. A slight pull on the foam and you can see it is not connected. I pulled on the top part as well and it is still attached. Probably something you won't notice until you are in the trailer in a heavy down pour but what happens when you are not there is terrible.
  • Guess I better get out and check my speakers. Don't use them but the water leak issue.
  • By the way, it's been years since we've had a good Outdoor Speaker thread here. These threads used to really rile up the non-Toy Hauler members.
    There's a similar thread running in Tech Issues and the members over there haven't been as sympathetic to the OP's questions. Lots of people clutching their pearls at the mere mention of outdoor speakers.
  • Our speakers have always been a mess.
    The first time I used them, I had them faded to play quietly in the garage and a little louder outside. I was sitting out there thinking, "Hey, that's not how this song is supposed to sound." And then when I was in the garage, I had the same sense about another song. So I started playing with the fade and the balance and finally figured out that the builder had taken a shortcut and ran one line to the garage for the right channel and split it into two speakers, and did the same to the outside speakers and split them both into the left channel. Ridiculous.
    That was an expensive warranty repair, because the dealer had to run a whole new line all the way to the front where the speakers are.
    It's a few years later now, and the speakers have worn out. The paper cones are destroyed. I had put this on my list of things to deal with in the new year, but then Santa brought me a killer Bluetooth setup that sounds way better than the crummy stock speakers ever did. So I'll probably just leave them as they are.
  • The speakers on both toy haulers were outdoor speakers. Two different brands of toy haulers as well. I am just trying to point out a problem I had before anyone else has the same problem and suffers severe floor damage from a speaker failure.
    Thanks for the tips and ideas. I never thought about using plumbers putty behind the speakers. The Kenwood speakers I installed on my first toy hauler had a rubber gasket and then I caulked all around the speaker and put caulking into the screw holes prior to installing the screws. I never had a problem after that with them.
  • Should’ve had marine speakers all along for any outdoor speakers. Replace and use plumbers putty behind for the seating. Easy peasy.
  • I replaced the cheap outside speakers on our trailer with these PolyPlanar MA-905 marine speakers. They have mylar cones with rubber surrounds, not foam.
    I mounted these so that the woofer sat in the hole from the factory speaker and they fit perfectly. Decent frequency response (55hz on the low end) and plenty of capacity. I added a Kenwood 200W power amp with speaker-level inputs after the factory head unit and you could hear these halfway down the beach!
    You can get them for a good price on Amazon.
  • Those factory speakers are not worth anything. If you get real outdoor speakers you will have sound good enough that all your neighbors will be able to enjoy your music and they will not leak.
