roller183ExplorerDec 17, 2014Parallax power supply noise model 555The Parallax power supply converter has worked flawlessly for the last 7 seven years. Now when a light 12volt is on, you can hear a high pitch noise come out of it. Looked at some other sites said...Show More
midnightsadieExplorer IIDec 18, 2014do as PEG LEG SAYS .the progressive unit is great and they,ll talk you thru the change if needed.
Related Contentparallax power supply 7345ru parts PWMParallax Power Supply 7345WFCO Charger/Power SupplyNo power on outside GFCI outletAdding power outlets in slide with no wiring
