Durb
Jul 28, 2017Explorer
Consider this. When you pull out of your driveway with the 5er you will cut the inside corner more than with a bumper tow. In theory you will need to cut the inside corner more when backing in. If you don't have cut room on the corners to create a line it could be a problem. I had a similar scenario went from 25' BP to 31' 5er. I can get it in but it is more work and I do have to cut the corner more to create a backing line. I also have a lot of pull forward room to make adjustments which for me are necessary. I know others have skills and can put their trailer just about anywhere they want.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
