KD4UPL wrote:
How in the world do you get furniture that size in the tiny little RV door? Or is this a toy hauler?
I was going to change out the mattress in my TC once but I couldn't figure out a way to remove it.
First, you measure, measure, and measure again. Second, the back come off the couch. Third, the arms on the couch are filled with foam and can compress.
The couch was just a bit longer than the door was tall, but turned on end, the top of the couch went in the door first. I was on the inside and 2 men on the outside lifting it straight up. Once the top cleared completely, they lifted the bottom (ceiling had plenty of room). Once inside the door, it was standing on end. I had to turn it on end, then because of the configureation of our camper, I could simply walk it down in position.
After it was inside, I had plenty of room to move it around with the slides out. I eventually flipped it upside down. I drilled 6 holes in the frame and put castors through them. Flipped it back over, put the backs back on and .... whola!
We looked for quite a while for the right couch. We actually bought at Value City Furniture near Indianapolis.
