Fishinghat
May 12, 2013Explorer II
When we've stayed at parks with 50 amp at the site, we were changed a flat fee per day that included power. If the same park had 30 amp sites, they sometimes would be less, but only because the site was not as "improved" or new as the 50 amp site.
As for monthly rent, the power usage was based on amperage used, not how much was available. So, if you are connected to 50 amp power, you may not use any more than you would have used if you were connected to 30 amp. You could use more since more amperage is available, but that doesn't mean you will. So, regardless of which plug you connect to on the post, the amount of electricity you actually use will probably be the same. You could use more, but that is a choice you will make, not your RV.
So, if 30 and 50 amp service are both available at the site you are in, the park is probably going to charge you the same fee.
(After I posted this several others commented about amperage and voltage and displayed quite a bit of confusion over the terms. I didn't cover this originally since I didn't think it was part of the question. Voltage times amperage equals wattage. So, if electricity was a water hose, a big hose, like a fire hose, it could fill a bucket in X minutes at low pressure. A small garden hose could fill the same bucket in the same amount of time if it had high pressure. That's the difference between low voltage (big hose) and high voltage (garden hose). Amperage is the size of the stream of water coming out of the hose being pushed by the voltage. Not the speed, the size. Wattage is the net result. I hope this helps explain the common confusion with electrical terms.)
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
