Old-Biscuit
May 12, 2013Explorer III
When I first started learning about electricity a good analogy was to define it in terms of water.
Voltage is the same as the water pressure in a garden hose.
(Even if the valve/ spigot is shut off, there is pressure/ voltage available)
Amperes would be the number of gallons/ electrons that flow, per second.
Ohms would be the pipe size/resistance
Watts would be the number of gallons/ electrons that flow, per second, times the water pressure/ voltage.
50A...has a much higher 'flow capability' (watts used) than 30A
50A.....120V x 50A = 6000W x 2 = 12000W
30A.....120V x 30A = 3600W
So which one should cost more?
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
