Well finished the PDI and they did everything I asked for it makes you know for sure if there are any leaks between the Tub/floor and toilet/ floor seeing water all the way into both with all tanks completely filled. No leaks were found so piece of mind there. I would recommend to anyone have all tanks filled so all connections are tested a lot easier with clean water then doing after tanks are used. Took it for a test drive as leaving for the rest of the winter and did have a little Porpoising, so when go back up will see if can be completely eliminated. I want to thank everyone for their input was a great help.
