rfloyd99's avatar
rfloyd99
Winterizing Question
I'm winterizing my TT for the second time, following the instructions in the TT's owner's manual. The pump is plumbed with a pipe designed to be inserted into a container of antifreeze so you can pump AF throughout the entire plumbing system. This seems to result in all the pipes being full of AF, including the part of the water pump that water (and AF) pass through. This is what I did when I first winterized it three years ago. The RV survived a very cold high-altitude Colorado winter with no problems.
This time I read the separate water pump manual. It says to disconnect both inlet and outlet pipes and run the pump until all water is expelled. This would be a PITA, and would probably result in water on the pump compartment floor. The manual doesn't seem to contemplate that I could be pumping AF throughout the system. It just suggests that AF be poured down the drains to protect the P traps.
My 1st question is, can I ignore the WP manual since it seems the pump's water-containing parts will be full of antifreeze?
2nd question: The TT manual says to open the low point drains, then close them after all water has drained out of the tank. The drain valves are cheap plastic - if they're closed isn't it possible the valves could have some water in them that would then freeze? I don't remember what I did three years ago.
Some of you must be very experienced at winterizing - any suggestions?
Thanks.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
