- kab449Explorer
camilllit wrote:
I've since read ...........first front window on driver side of rv. We found it, it was on driver side of the pin box!!!!!!! You can hardly see it, an inspection sticker on a black surface.
That’s it! - bobsallyhExplorer IIlacnox, PA. state inspection is nothing like the Lonestar inspection. Been though both and they are not comparable.
- laknoxNomad
sayoung wrote:
laknox wrote:
pinesman wrote:
In Virginia, a lot of them used to be placed on a driver's side window. A couple years back they changed it to the pinbox or tongue of the trailer here. It would be good if all states used the same location but that probably will not happen.
Inspesions? We don' need no steenkin' inspesions in Norte Mexico, I mean Arizona! :B
Lyle
Texas started this absurdity several years back. Here it's gvwr over 7700 or so because the boating industry had a great lobbiest so ithats why it's not lower. It's a pain as only certain stations can inspect & the rv must be inside the shop other than the brake check. The only good part is no sticker any longer, just a paper to carry with you but it's on the computer.
Any way to make more cash...:M
Lyle - sayoungExplorer
Lyle
Texas started this absurdity several years back. Here it's gvwr over 7700 or so because the boating industry had a great lobbiest so ithats why it's not lower. It's a pain as only certain stations can inspect & the rv must be inside the shop other than the brake check. The only good part is no sticker any longer, just a paper to carry with you but it's on the computer. - camilllitExplorerI've since read ...........first front window on driver side of rv. We found it, it was on driver side of the pin box!!!!!!! You can hardly see it, an inspection sticker on a black surface.
- PA here. First window on the drivers side. Which puts mine about half way back the 5th wheel.
- laknoxNomad
Lyle - pinesmanExplorerIn Virginia, a lot of them used to be placed on a driver's side window. A couple years back they changed it to the pinbox or tongue of the trailer here. It would be good if all states used the same location but that probably will not happen.
- RobWNYExplorerI found this regarding PA Inspection sticker location. It appears it goes on the side of the trailer, 6' up toward the front but not on the nose.
On trailers, the certificate of inspection shall be affixed, in an upright position, to the left front—traffic side—of the trailer, approximately 6 feet high, if possible. The certificate may not be placed on the nose or front side of the trailer. A holder is permitted if it is in the proper location and the certificate of inspection is affixed to prevent theft or transfer to another vehicle. The new certificate of inspection may not be placed over the old certificate of inspection.
I referenced this site for the information: Click - dblrExplorerMost of ours when we lived in Pa were always on the first window on the drivers side except in a 5th wheel were they are up high in the front.
About Fifth Wheel Group
