mrxlh
Mar 20, 2014Explorer
Lyrikz wrote:mrxlh wrote:
Congrats on the new rig, looks nice. Let us know how much it costs to fix when you have your first blowout on the camper. I give your rear diff a year before it heads south.
This******right here. The rear diff. has the same bearing setup as the DRW. So that statement is just crap. The extra two wheels wont help save my diff. Now if the DRW had larger bearings then i would be concerned. You are just spouting out nonsense.
A dually axle is a floater, your single is not, so yes, there is a ton of difference between the two as far as how they are built. As far as the ST tires on a triple axle heavy hauler, I give you exhibit "A"
The amount of damage was more than a set of LT rib tires.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
