- CenTexExplorerThere's an old saying among RVers. The cheapest thing about RVing is the price of the RV. Its all the peripherals that go along with it that gets you. It totally depends on how much you want to spend. Assuming you already have a truck big enough to tow the trailer some of the big ones are 5th wheel hitch 1200 to 2000 depending on what you get and where you get it. Electrical adapters and 30 or 50 amp extension cords, that can be a few hundred dollars, RV barn, not a must but I like keeping my fiver under cover. There again it depends on what you get as to how much you pay. Those are some of the bigger things. Its all of the little things that nickel and dime you to death. Tire covers, all the things you see at Camping world that you can't live without, trust me I am like a kid in a candy store when I go there. I have two sets of everything. one for my house and one set for my trailer. It saves moving everything in and out of your RV every time you get ready to make a trip.
- bpoundsNomadThe most important things to take with you on a maiden voyage, is patience, and a spirit of fun and adventure. Some things are going to go wrong. Manufacturers fault, dealers fault, your fault, or maybe all three. Expect that and you won't be disappointed. Insist on having fun no matter what.
- GoostoffExplorerAwesome trailer. We looked at this one last week. There is a lot of trailer there for the price. Aside from the hoses and cords and stuff make sure food prep is in order. Are you cooking over the campfire? You will need a device for that. Are you grilling? You will need gas or charcoal. Make sure the LP tanks are full too. Never know when you will need it.
- Dog_FolksExplorer IICongratulations.
Camp in your driveway the first night, and make a list.
Take your time completing the Pre-Delivery Inspection and do this BEFORE signing any papers or paying any money.
If there is anything wrong, and there probably will be, and the dealer promises to fix it: Get it in WRITING or have the dealer fix before you sign.
DO NOT TRUST ANY ORAL PROMISES. In many states, with a written contract, oral promises cannot be enforced. - jnharleyExplorerChocks should be the first thing you use when you back in/pull thru a site. Then water, sewer hose, and electrical cord. The rest for the inside is whatever else will make you comfortable.
- MC9ExplorerSorry, that is not a water pressure regulator, it is a backflow preventer. Continue on..
- MainerBobExplorerReading this thread, something occurred to me. At many campgrounds there is a water pressure regulator on the hose bib, usually secured with a set screw. I also have one on my inlet. Does having two affect my incoming water pressure or doesn't it make any difference? Sorry to hijack the OP's thread.
- BumpyroadExplorermake that a multi-function surge protector. $250 on up. not the $90 special. and a decent watts type water pressure regulator, not a $9 walmart special. you can make life easier/cleaner by buying a macerator pump and skipping the stinky slinky.
bumpy - SDcampowneroperExplorerGo to a nearby short term stay campground a couple of days for a 'Shake Down ' cruise. Approach your neighbors for tips, study their set up. Pay attention to how and with what they level, hitch, unhitch, stabilize, dump, winterize, dewinterize, awning tricks, all the thousand ideas of a home on wheels.
Pick out what is right for you, all the while listing what you left behind, what you brought you do not need for the next trip.
My suggestion is lumber scraps for leveling and for under your jacks when the ground might be soft. and a skillet with a bit of water in it as your level. Water is always level in all directions. And you have a skillet, no need to bring along a level, right?
Forget lego blocks, sewer hose slinkys, or expensive toys until you have some experience. A good Watts water pressure regulator. Until you have one, just use your fresh water tank and pump. no worries of high pressure that way. Or of having no water after a freezing night.
Be careful when opening and closing slides, quit trying when you hear the slide motor labor the tiniest bit. Save the shear pin.
Extend your front landing jacks enough to let the nose back down when it is high unhooking, extend the drop legs enough that the jacks can raise it enough when front low unhooking. Do not over extend or bottom them out.
Welcome to the life! - hammer21661ExplorerI recommend a rhino flex sewer hose they are worth it.
About Fifth Wheel Group
