If you're talking about when you pick it up at the dealer, make sure you get up on a ladder and look for cracks in the Gel Coat on the nose of the RV. While you're at it, get on the roof and check things out. I thought I had done a pretty thorough job of making sure everything was fine when I bought mine but never thought to do that. When I got it home and decided to give it a good waxing, I noticed all these spider cracks in the Gel Coat. You can't see them from the ground but they sure can be seen up close on a ladder! If you're not spry enough to check yourself, bring someone with you that you trust that can do it for you. What a nightmare I've had trying to get things fixed!
