Tdavid's avatar
Tdavid
Pickup rental?
I've got a challenge on my hands. I want to get my non-com Class A license in PA, but my current pickup has a max GCWR of 23,500lbs. From what I've learned you need to take the test in a rig combo that can legally exceed 26,001lbs GCWR.
I ran my current truck and 5er over the scales, and I'm within all my permissible weights (pin, rear axle, GCWR), with a GCW of 22,800, but my GCWR would be 28,150 as per the stickers.
So I technically need a non-com Class A license.
I have a Reese Goose Box hitch on my 5er, set to match the frame receiver as per the install instructions (which also resulted in a perfectly level trailer on my truck). I see a place near me that rents flat bed Ram 3500 Aisin pickups with goose neck balls. Can I rent one of those to take my test? Not sure the geometry difference between pickup bed and flat bed.
