Cummins12V98
Dec 20, 2018Explorer III
valhalla360 wrote:Cummins12V98 wrote:
Most likely the overhang won’t be level even if RV is level. My overhang slopes up towards the front some.
Check if this is the case.
2" from tailgate to hitch is a lot if the bottom of the overhang is parallel to the interior floor.
That would be an insane amount!
Get the RV level by adding planks under the RV's tires as mentioned. See if that changes the tailgate clearance. The shimmed amount will tell you how much to raise the RV/lower suspension minus the increase of the tailgate dimension.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
