Durb
Dec 13, 2019Explorer
garyp4951 wrote:
I'm confused, I have always thought chucking is the forward, and backward motion.
You are correct. Many on this forum think chucking is just hitch noise. The trailer generates fore/aft motions when it goes over bumps. All trailers are different and the amount of chucking forces vary. When you are bouncing off the seat backs and your wife has to hold her chest, you know you have a chucking problem.
Some blame chucking on a hitch and suggest hitches that don't chuck. If the hitch caused chucking it would be evident when the trailer isn't hooked up. It isn't, the trailer generates the chucking forces.
There are ways to make trailers chuck less like better axle equalization, trailer shocks, and loading. There are also design implications like length and mass placement that cannot be corrected. One tactic is to harden the rear suspension on the truck (via air bags) to keep the trailer from pushing down and, at the same time, not pushing forward. This works but is hard on both the truck and trailer.
There are two basic types of hitches and pin boxes. There are solid hook-up styles that transmit all the trailer generated forces to the frame of the truck. There are soft joint styles that convert trailer generated forces into heat and dissipate them (air hitches, MorRyde, air pin boxes). These devices don't stop chucking forces, they just make sure they don't reach your seat back.
The thought of airing down the trucks tires seems absurd to me. Think about it. The trailer pushes forward on the pin box, the pin box is securely attached to the hitch, the hitch is securely attached to the frame of the truck which is attached to your seats. Why would airing down the tires help as they are totally removed from the energy path? If anything, sidewall compliance could cause the trailer to push further down and, at the same time, push further forward making chucking worse.
There are the lucky few that don't notice the chucking forces their trailers generate. You will find they fall in to the camp of "Since my trailer doesn't chuck, therefore yours won't either if you have the same gear". They are easy to identify.
About Fifth Wheel Group
