cummins2014
Dec 13, 2019Explorer
Cummins12V98 wrote:
Absurd? I am sure you are referring to me on airing down tires. I said to air for the load! That may require MAX or as my Dually says to air to 65psi for RAWR.
So should I run 80psi???
Like usual my words are twisted to serve ones argument. NICE!
Then what are you trying to say . I read you are saying inflate your rear tires to their weight rating on an inflation chart . My rear tires have a max weight rating of 3640 lbs, or 7280 total thats what I can carry on those two rear tires at 80 psi, and if I only have 6000 lbs on the rear tires or 3000 each ,then I should inflate to whatever that weight chart said. Do I have it right . If I don't then it could cause chucking . Do I have that right also.
I see that no one is really agreeing with you on your assessment. I don't , I run my rears at max psi when towing my fifth wheel . My fifth wheel tires , I run close to max psi 110, they don't need that much according to the inflation chart, but so be it, I am not going to run them that low .
I don't think anyone is twisting your words, I think you are upset because they are not agreeing. I sure don't ,at least on air pressure ,and chucking.
About Fifth Wheel Group
