cummins2014
Dec 23, 2019Explorer
TxGearhead wrote:
If you are considering the Morryde do you know which rubber spring is in it? I think it should have a decal on the side with max GVW. I'm running with about 4100# on the pin and around 17,400 total. Mine is rated for 18,000, so I'm close. My Morryde is slamming on starts and stops. I have a heavier rated rubber spring on the way to replace. On the road my ride is ok.
Just be aware there are different rated springs.
Did that slamming on starts ,and stops just start happening, or has it always done that. Reason I ask ,mine seems fine ,but its got some miles on it, and curious when the rubber spring needs replacing. I replaced the shear springs in the MorRyde suspension they were shot.
Also curious where you got the replacements. The shear springs were all over the place as far as price . MorRyde was the middle of road on price, found them quite a bit cheaper elsewhere .
About Fifth Wheel Group
