Brokedown
May 09, 2013Explorer
mguay wrote:Dave H M wrote:
The pin box bolts were so loose on my Laredo that they showed some movement as evidenced by the washers being moved from the original paint line. I replaced them with grade 8, torqued them, painted around the washers and never looked back - except to check for paint separation that is.
My Laredo did the same thing and my fix was the same as yours! Been good for 3yrs and about 20k so far...
Be careful changing the grade of your fasteners! Some bolted connections are engineered with a "sheer" factor and if changed may cause an adverse effect.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
