Jhurk's avatar
Jhurk
Pin box hits bed rail
Hi guys just joined forum. I sold my 39' class A now doing the truck and 5th wheel.
I purchased a 2014 Dodg Ram 3500 diesel short box. I installed the Anderson Ultimate Goose neck hitch. Purchased a 2009 Cardinal 30TS. When I picked up 5th I had to adjust the ball on hitch to highest level and reverse adapter to 5th hitch so adapter was cloaked to 5th. The pin box when doing about a 75 deg turn may hit the bed rail of truck? The fifth is nose high but not to bad. I towed 5th home towed very good. Now I have to raise the 5th to have pin box clear bed rails. Options? Flip leave springs on,5 th or spacer to raise 5th?
Anybody have any other suggestions.
  • I don't believe you mentioned the clearance between the bed rails and the fiver. Since you have the ball socket behind the pin, you have already shortened the pin box by 4". I wonder if you lowered the ball so everything was more inside the bed, if it would give the pin box a little more room. I have a long pin box, have the adapter backwards, the Andersen ball at its lowest setting and it solved the issue I had of the back of the pin box hitting the bed sides with a regular Reese hitch. I still have 7-8" above the rails and am still a little nose high.
  • Well I got my Cardinal back and all is level and the pin box cleares the box rails. I can do a full 90deg turn and I am clear of cab and bed rails! They raised my frame 5" and cut about an inch of the pin box for good measure. The only issue now is my step is so high I need at least one more step (4 steps) I'll have to research options. Also I will have to measure my new height but should be under 13'6"!
  • Google Stromberg Carlson PA-250 adjustable step. I have been using one for 4 years now. Works great.
  • I didn't see where you said the pin box DOES hit the rails. You said MAY hit the rails. When you say "rails" do you mean aftermarket chrome (or other) bed rails or just the actual side of the box?
    i take my chrome box rails off for summer when towing fifth and fifth is nit even close to the box sides. . There is a big difference between pretty and functional.
    It would have it the bed rails or the top part of the box if I didn't make the adjustments. There is nothing on top of the bed rails no aftermarket add ons.
  • OP do you have the ram box option on your truck?
    No Ram box option. I had the B&W turnover ball system installed seems like a good application. Not cheap cost nearly as much as the Anderson hitch!
