Nevadastars
Jan 02, 2017Explorer
Pin height?
Is there a standard pin height from the ground while the unit is level on later model fivers? I can't seem to find that info on the spec pages I found. We live in a small town with no RV dealers, so c...
MFL wrote:
I think the later model FWs generally have a higher pin than older models. If you look at mid size and up FWs that are 5yrs old or newer, you should be able to tow fairly level with a stock 10yr old truck.
IMO, it is not a problem, if towing a FW a couple inches or less nose-high. Keep in mind, the more pin wt added, will make the truck squat more.
Jerry
