Is there a standard pin height from the ground while the unit is level on later model fivers? I can't seem to find that info on the spec pages I found. We live in a small town with no RV dealers, so c...
Our 2014 Keystone Alpine 3500 RE when level the pin plate is 50.5 inches from the ground. B&W companion height from ground is 52". With 50 psi in airbags on our 2010 Ram 3500 4x4 megacab it is level going down the road and 6.5" bed rail clearance. These figures are for our truck and 5ver and your numbers will be different. Hope this helps you figure this out.
