Is there a standard pin height from the ground while the unit is level on later model fivers? I can't seem to find that info on the spec pages I found. We live in a small town with no RV dealers, so c...
If you go to that RV show you mentioned besides bringing a tape measure bring along a small level. The show folks don't always level the units so you could end up a few inches off one way or the other. When you're trying to make sure you have enough clearance between the TV bed rails and the front nose of the RV, you need to get accurate dimensions.
