MTPockets1ExplorerOct 27, 2014Pin weightHow many know their actual pin weight. Serious 5vr's should. Most discussion regarding trucks are more about towing capacity, when it needs to be about pin weight which is the biggest part of cargo ...Show More
valhalla360NavigatorOct 27, 2014I'm around 30% under based on the dry numbers, so apparently, I'm not too serious...but I'm pretty comfortable with it anyway.Now if your dry numbers are pushing 90% of the max ratings, it's probably not a bad idea to weigh the rig and find out where you are.
