spud1957 wrote:
I like using the dry weight ratio. Once loaded, the weight ratio would be similar.
If the posted dry weight of the trailer is 10k with a dry pin weight of 2K. That unit has a 20% ratio. Load it up to 12k and you will be close to 2400 lbs.
Some units' ratios are lower. Some are higher. Floor plan has a lot to do with it.
On all the 5th wheels we've owned since 1996, loading the front storage bay results in the trailer being heavier on the pin than the dry pin/axle weight ratios would indicate. In other words, a 20% "dry" ratio might turn into a 23% or 24% "loaded" ratio.
Rusty
