lawnspecialties wrote:
Agreed. I just want to know a good way to find out EXACTLY what a unit's pin weight is BEFORE I buy it. The 20% of GVWR is good and all but its still an estimate.
I am more than a little lost on why you need to know EXACTLY what you pin is going to weigh.
If you are concerned because you are pushing payload then you need a bigger TV!
If you just want to know good, luck, take empty trailer and it's pin and then figure out were you are adding weight, then figure out how that affects the pin. Keep in mind tandem axles are not a perfect fulcrum.
