lawnspecialties wrote:
Lantley wrote:
The best way to find out the real pin weight is actually measure it.
There is a Sherline scale that can handle up to 5000 lbs.
Sherline
Model No. Dual-ring Gage Ranges
LM-1000 0-1000 lb/0-460 kg
LM-2000 0-2000 lb/0-900 kg
LM-5000 0-5000 lb/0-2250 kg
Excellent. Did not know that. I'll call eTrailer tomorrow but if they don't have it, I'll order Amazon tomorrow. Thank you.
I have seen those used for TT weights but how the heck would you use for 5er pin weights? You have to get level or at the same angle you tow at to even get close.
