ford truck guy wrote:
Perhaps I am wrong here??? BUT I thought this was about a guy looking to BUY a new camper.. There are 2 issues -
#1- who actually loads their possible new camper on the dealers lot just to see the weight???
#2- what dealer in their right mind will allow someone looking at trailers to load one up , then get it weighted ???
That's WHY you go by the GVW and the worse case scenario ..
The problem is that you don't know what, and how much, "stuff" you're going to be carrying. Also, the mfrs are =very= reluctant to release plumbing schematics so we can know where the tanks are supposed to be. If I knew where my fresh water tank is located, the one that's most likely to be filled when traveling, I could use it for ballast to offset a heavy pin, especially if it's somewhat behind the axles. As others have said, the pin wt ratio can drastically change as you load up.
Lyle
Lyle , I agree with you... BUT-
I don't know of any dealer that will allow you to fill the camper UP with your stuff AND take it to get weighted.... That's a huge liability ....that's why you need to go off the worse case , if your truck can't do it , go bigger...
Here is my plan. I KNOW for a fact that my dealer that I usually deal with will allow me to do this. They are a huge toy hauler dealer here on the east coast and I have bought two campers from them. I got to know them all very well when we had that horrible Cyclone. We spent so much time up there having service work done, we all got to know one another on a first name basis.
Sometime soon, I will go to the nearest CAT scales and have the truck weighed full of fuel with me and the wife. Then I will know extremely close what my available payload is for the truck and the rear axle.
My Sherline scale will be here next week. When we're ready to go looking at campers, I will take the scale with the truck and some 6"x6" pieces and build up a block in the bed of the truck at height of the fifth wheel hitch.
I can then back underneath the camper and lower the pin onto the scale so the landing gear just barely comes off the ground. I now know the dry pin weight of that camper. I can estimate a couple hundred lbs. of extras for when we're loaded and then I will know if I'm completely safe, getting close, or overloaded.
As many people here on rv.net scream about folks being overloaded, I must admit I'm surprised at how much drama this thread has created. I'm trying to know what I can and can't do. Is that so wrong?
